Almot
Oct 08, 2017Explorer III
westend wrote:
If you have a loss of pressure, elevate the aux. storage tank. The small diaphragm pumps used in most RV's do not have a big pump head lift.
I didn't notice a loss of pressure with 1/2 tube on aux tank. Little ugly noise-maker is pushing same sub-par flow (compared to average shore home) with same disgusting noise as it was with the built-in RV tank :).
The aux tank is sitting on the ground, its bottom is ~1ft lower than the trailer tank, but it's taller, so half the time the water level is at least same high as it would be in RV tank.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
