mobeewan
Oct 08, 2017Explorer
With the tank sitting on the ground part of the water in the tank is going to have to be lifted higher than the water that would normally be in the onboard tank. The pump will have to work harder then it normally would to lift it that distance. The Shurflo pumps are designed to lift water about 12 feet using 1/2 inch ID tubing so your tank on the ground is well within the operating parameters. However, keep in mind when switching to three quarter inch pipe (1.066 OD/.824 ID for standard schedule 40) your internal diameter will be significantly larger and your volume and weight of water in that pipe that the pump is lifting will more than double and the pump will be working harder especially while self-priming to lift that amount of water.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
