joshuajim
Oct 09, 2017Explorer II
I don’t think the “weight” of the water has any effect. Pumps don’t actually “suck”, they create a low pressure which allows atmospheric pressure to push the water to the low pressure area. A larger pipe hs a larger cross section for the 14.7 PSI pressure to act against.
That is the exact reason that most pumps cannot lift water more than approx 33 feet.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
