slowleak's avatar
slowleak
Leaky roof vent
I've got a vintage Kamp-Craft trailer with a vintage roof vent that leaks. The vent assembly isn't easily replaced and my only option has been to replace the plexiglass in it.
Its a bit different than most, the entire vent is steel other than the very top which has a slight recess and a plexi glass insert glued in place. When I got this thing the plexiglass was missing, someone had it tarped over with Gorilla tape. I cleaned and soda blasted the frame, measured and cut a new 3/16" piece of plexiglass to fit. For the first few weeks all was well, till the sealer let go.
I used marine grade urethane the first time, when that let go I tried the black urethane they glue car windshields in with but it too came unstuck from the plexiglass. Finally, just before winter I sealed it with Butyl rubber tape and it lasted only 4 months, the plexi glass blew off the minute the temps dropped below freezing.
I've cleaned both surfaces with alcohol, the metal frame is primed with self etching primer and each sealer adhered fine to the painted surface, its the plexi it won't stick too.
I'm at the point where I'm thinking of just cutting a steel panel and welding in a metal cover. If the plexi fit over the vent, it would have half a chance but the plexi glass just sits on top in a recessed ledge.
Replacing the whole vent would be nearly impossible since this the surrounding frame or reinforcement in the fiberglass roof is about 26"x22" and its corrugated to match the shape of the roof.
All of the newer style vent covers are flanged and fit over or contain the hinge, on this one the hinge and lifting frame are all part of the main assembly.
At this point I'm thinking welding on a solid top may be the only option if I can't get something to make the plexiglass stick to the steel. So far its blown off in the yard, its never made it to the road yet. It seems like the adhesive just can't take extreme temps.
Does anyone have any suggestions before I fire up the welder?
Moderator edit to re-size picture to forum limit of 640px maximum width.
  • The problem with finding a new vent assembly is the the flange on this one is made to match the corrugated roof surface. A flat flange vent would never seal around the edges without a ton of caulk.
    If I was more confident that welding in a filler panel wouldn't warp the vent lid and create another issue I think I'd have gone that route first.
    The part that gets me is that I've used the same sealers with the same materials on my boat with good results but never where its exposed to direct sunlight on a roof before. This time it let loose when the temps dropped below freezing. I feel its got to do with the dissimilar expansion rates of the plexiglass and steel.
    The problem now is that it's too cold to try and seal it again, it'll have to rely on a tarp till the weather warms up.
  • Have a similar set up with the cabin glass windows on my boat. I have to pull them every couple years to reseal them. They have a much bigger set in seat with with to achieve a seal, so it lasts longer, but they often leak. I have to keep it under cover to keep things dry in winter, and I am a fair weather sailor in the summer.
    I see your problem, and can't come up with anything more than you have done. It will be too bad you loose the light coming in through it, but ya gotta do what ya gotta do sometimes. I hope some brilliant person comes up with something for ya. We'll see. Some smart people are on here.
  • Possibly a boat supply would have larger vent you could use.
    Did you scuff up the Plexiglas with some really coarse sandpaper. That can gives adhesives a good grip. I would scuff up both surfaces and try some JB Weld!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
