coolmom42
Apr 22, 2016Explorer II
A lot of people do it with paint in modern fresh colors. Pale gray is the current favored neutral for walls. White cabinets, gray/black/white patterned fabrics. That sounds drab, but all it takes is a little pop of bright color in the fabric, plus a few accessories like cushions or curtains to pick up the same or compatible brights.
From what I've read, surface prep is critical to a good paint job. Re-glue any loose trim strips or wallpaper. You should be able to get those beautiful (not) borders off pretty easily.
Wash with a solution of TSP to remove dirt and grease. Sand very lightly with something like 100 grit paper. Then wash again to remove sanding dust and more dirt. Use 2 coats of primer, then probably 2 coats of the decor color.
I've done a fair amount of reading---if you google "redecorating RV" you will get lots of info. Also, make a Pinterest account to keep track of ideas from other sites. (Your wife or granddaughter can show you how to do that, LOL.)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
