12thgenusa
May 05, 2014Explorer
Well I don't believe it's interpretation. If your system is wired correctly, the solar output is wired in parallel with the batteries. Because of the lower resistance of the solar portion as compared to the batteries, any 12-volt draw will pull from solar before the batteries.
Solar will power anything up to its capacity. The batteries only kick in when solar max power is reached. In my case, 25+ amps will power a lot of things. I have many times seen the solar putting out 17 or more amps with only 2 amps going to charge the batteries.
On high draw items beyond the capacity of solar only, it still contributes up to its limit. I've watched it contribute 23 amps toward the total 86 need to run the coffee pot or the 132 needed for the MW.
Batteries don't make power, only store it. All of the power comes from the sun.
At least that's how my system works. I wouldn't be satisfied with anything less.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
