sjturbo
Jun 25, 2014Explorer
I ran into the same issue. The zip tie is a good suggestion as is the 3m molding adhesive. I went with a dollop (for the culinary minded) of silicone? We will see if it fails. Should be easy to peal off if needed.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
