EMD360
Jun 27, 2014Explorer
So they let go? Most of ours did in the AZ heat (despite cleaning with alcohol) so I just let them sit in the plastic covers. Some of the wires are pulling loose with travel. I didn't get the correct light bulb connectors with ours and had to glue them into broken bases of the old bulbs! Maybe it is time to re-look at this solution....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
