SpringerPop
Jul 05, 2014Explorer
These are what I used, too.
I peeled off the adhesive it came with, cleaned thoroughly with iso-91% alcohol, cleaned the inside of the reflector, and ran two heavy beads of clear RTV (silicone)/ Then, pressed them down into the reflector, allowing a bit of the RTV to squeexe out of the edges. Placed a light weight on it to hold it down while curing, and soldered the wires directly to the bulb socket.
If I had to do it all over, I'd do it just like that again.
I used the warm-white ones, as that's my wife's preferred color.
Pop
Pop
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
