gazingm42
Jul 13, 2014Explorer
We had the same problem. I worked on a solution for several weeks last year. Finally I used Velcro with the stick tape. Working in the service field on computer I also have a different view on anything I work on or build. That is how will I repair/replace it when it fails. For this reason I used Velcro because
I did want new double side to have it stick and with heat maybe not be able
to remove it.
But saw the zip tie idea which maybe a easier solution.
to remove it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
