4x4van
Jul 22, 2014Explorer III
ktmrfs wrote:
Been there, done that. These LED strips
a) don't use 3M VHB tape but something much inferior
b) don't use current regulation but a dropping resistor.
the combo is a bad combination. LED current is an exponential function of applied voltage. LED's are 10-15% efficient, the rest is heat. Fine at 12V nominal, charger goes to 13.6 or 14.4 and you found out what happens. In some cases the LED will get hot enough to melt the solder.
short term solution is to use silicone adhesive or real 3M VHB tape.
If you don't do much camping (a few weeks/yr) they may hold up.
We do lots of dry camping. These ended up very short lived. (well about a year but that was over 100 days camping). when hooked to shore power or generator or solar charging the batteries in bulk mode, the LED's overheated and eventually got very dim and finally failed.
solution is to spend the bucks and get arrays that have a built in current regulated supply.
So far, I haven't had any runaway heat issues even though I am using the inexpensive LEDs. I've let them run continuously for 4-5 hours straight, while using shore power (13.8v), in 90+ degree ambient temps. The 48-5050 arrays got up to about 200 degrees and no higher. That's only about half the temp of the incandescents they replaced. My long strip lighting did even better, settling in at only about 120 degrees. I've had them now for a year; about 8 3-day camping trips, half while boondocking, half with full hookups. Not a single LED has failed and they are still very bright.
I did have one single array come loose (the two corner dots of silicone pulled the paint off the inside of the fixture), but that failure was NOT from heat, as the light was only used about 3 times, for 2-3 minutes each time, as opposed to the others which have seen use for hours at a time.
So for me anyway, current regulation would have been a waste of money; the dropping resistor built into my units have done the job wonderfully. Interestingly enough, I see very little if any difference in brightness between battery power (12.6v) and full hookup (13.8v). Did I get lucky with the "cheap " units that I bought? Perhaps, but I'm not going to argue with success. :)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
