ryanallie1
Jan 10, 2015Explorer
gazingm42 wrote:
We had the same problem. I worked on a solution for several weeks last year. Finally I used Velcro with the stick tape. Working in the service field on computer I also have a different view on anything I work on or build. That is how will I repair/replace it when it fails. For this reason I used Velcro because
I did want new double side to have it stick and with heat maybe not be able
to remove it.
But saw the zip tie idea which maybe a easier solution.
Hi All.
Yes the Zip-Ties might work. That is if you have the type light fixtures that you can use them on, in the first place. The type light fixtures that are in my Motor Home, Zip-Ties can not be used, period. That's why I went with the Heavy Duty Black Velcro. Still holding, no matter what the Heat Range or Sub Cold Ranges are.
Happy & Safe Travels. Dan & Austin. Full-Timers & True "Spirits of the Wind".
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
