vlopddap's avatar
vlopddap
LED dome light upgrade won't stay in place
I purchase a large quantity of 24 LED panel (SMD 5050) over eBay to upgrade all dome/wall/cabinet/exterior lights of my trailer to LED (cool white). I order them from eBay and they are AWESOME. Light is powerful a LOT and no more yellowish light inside the trailer! The price is kinda incredible too... 20$ for 15X units.
I only have one issue so far and I want your advice... those LED panel came with a double-sided adhesive on back of the panel to mount inside dome light. But after a few hours of use and because those SMD 5050 panel became a little warm (not hot, just a little warm), the cheap double-sided adhesive felt appart and LED panel won't stay in place anymore.
Any suggestion? I'm pretty sure many other people experience this issue here... do you use a industrial adhesive maybe or silicone glue maybe? Or maybe there's some kind of true heavy-duty double-sided adhesive?
Even with this minor issue I do recommend this upgrade to everyone, light is awesome and low power drain too!!
Thank you!!
  • the zip tie is a good solution, I can see how any adhesive could fail due to heat over time.
  • Here is what I did...looped a zip tie around it and behind the reflector inside..I used a white zip tie. Can't even see it when the lens is on the fixture.
  • Hondavalk wrote:
    Could you drill 2 small holes in the fixture on each side of the lamp and use a zip tie
    Yes maybe, but I think I'll have to remove each fixture from the ceiling before drilling the holes which could be a long operation.
  • Could you drill 2 small holes in the fixture on each side of the lamp and use a zip tie
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 28, 2025
