PMcColley
Mar 27, 2014Explorer
Get the 5050s in a warm color. You can also get the 5050s in double density so you go from 300 in 16' to 600 in 16'. Then add a PWM Dimmer. Don't run your leds at full intensity or you will greatly reduce the life span. Besides if you worried about power on batteries being able to reduce the intensity of the leds will save power.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
