mileshuff's avatar
mileshuff
Awning LED light strip recommendations?
Need to replace the under awning LED light strip. Tons available on Amazon etc. Looking for recommendations from someone who has purchased and installed any of these.
Need a strip with flying leads to crimp/solder to existing wiring. Tried a strip from Camping World but it is very flaky. It has a 2 pin tiny connector with 1/8" long pins at end with mating connector that is much to flimsy for a reliable connection. It cannot be removed.
  • cooldavidt wrote:
    Anyone have experience with cutting to the exact length needed? Or using the outdoor light as a peer source(12v)
    Have to buy a strip designed to be cut. They'll have lines where you can cut, typically every 3 or so LED's.
  • Anyone have experience with cutting to the exact length needed? Or using the outdoor light as a peer source(12v)
  • I just installed Rolightic awning lights that cost 28.99. This was a plug and play for my trailer. My rv was prewired for awning lights. It took me about 15 minutes. Factory wanted $120.00 plus freight for basically the same lights.
