4x4van
Apr 06, 2014Explorer III
HwyGod wrote:
I did a permanent wiring job, running the wire from one side of the extended awing to the opposite mount side (runs diagonal within the rolled up awning).
The diagonal wiring idea is intriguing...how did you attach the wiring to the awning material?
HwyGod wrote:
The problem you are going to have with most is the adhesive.
I agree, and read enough reviews that said the same thing that I used a bead of silicone to attach my strip to the awning roller; so far so good.
I have a dimmer ordered, since the full length white strip is actually brighter than is needed at times. The dimmer should give me the ability to run full brightness or more "mood" lighting as desired.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
