GordonThree wrote:
0rion wrote:
GordonThree wrote:
btcruzer wrote:
So, do you do anything to remove the original adhesive from the light strip?
x2 on this... If folks are leaving the original tape on,then it's really what's doing the work.
My Chinese 3M tape seems to be holding better than the Gorilla tape I used to cover the pass through hole.
not really....the 3m tape will still be doing the work if you use it. It'll be what's grabbing the original tape not the other way around. I'm not sure if it's needed or not....I just wasn't taking any chances because the Chinese have been known to skimp on a few things. :D
but what's holding the led strip itself?
good point....I would still think that tape to light seal would be much better than the tape to RV seal. Guess I'll just have to cross that bridge when I come to it.
