George3037
Dec 27, 2018Explorer
I second the porch light. That's what I used. I removed the porch light and saw the wall behind it was hollow. I drilled a 3/8" hole 6" above the light and fed the LED strip wiring down through the 3/8" hole to the larger hole for the porch light and tapped the hot and ground so the LED strip comes on with the porch light. Then sealed the 3/8" hole with silicone caulk. I reinstalled the porch light with a new bead of silicone to seal it also.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
