DrewE
Oct 02, 2015Explorer III
I'm curious why you consider the square head screws to be "crummy". Do you not have a proper square-tipped (Robertson) screwdriver or screwdriver bit? They would be horrid with a Phillips bit, I suppose, just as a Phillips is pretty horrid with a flat bit.
At least in my limited experience, they are far less likely to strip out or fail to work properly than Phillips or flat head screws. The very first tool I bought for my RV was a decent square-drive screwdriver, and it gets a lot of use.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,407 PostsLatest Activity: May 01, 2026
