Almot
Feb 12, 2019Explorer III
deltabravo wrote:
Here's an easy project I did to replace the original light above the sink, which shined back in my eyes.
LED Lighting replacement
The problem with an old dome lights under the cabinet - too small and too focused. Panel is still not long enough for a 3ft counter. A long strip or tube would've been better, only I can't find one that is flat, matte/milky and long.
My problem with this blinding dome light was resolved by replacing the cabinet :) - made it few inches lower and normal 12" depth. Now there is an extra shelf inside, and doors are not hitting my forehead. The light is also lower now, doesn't blind. This solution might not work for you because of the window.
Those flat fixtures in the video would work on the ceiling too. thanks.
Edit-PS: have just realized that this type of flat panel doesn't have an On/Off switch?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
