Golden_HVAC
Nov 08, 2014Explorer
I was able to find some replacement 'bulbs' with the same base, and 9 tiny 5050 LED emitters on them.
AliExpress.com Then search for 5050 LED lights. Refine that search by the base type, and then check by lowest price first. You normally get a bunch of results where you need to buy a lot of 500 or so, keep going down the list or to the next page, and find a quanity of 10 or so. I bought 20 and they are 9 LED on the correct base. So I removed the 3 watt bulbs and installed ones that barely draw any power at all! I think it takes about 60 of the LED's to make 1 amp, or 6-8 bulbs for 1 amp.
Good luck!
Fred.
Good luck!
Fred.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
