doctorwedge's avatar
doctorwedge
Marker Lights
Looking for any advice or recommendations as to where one can purchase side marker lights for a 2007 pace arrow 33V . Any help would be appreciated as I am a newbie to the forum. Thanks
  • Look at the base to see if there is any sort of identification.
  • Try here: LED Marker lights
    Keep in mind that you will need the two wire marker lights, NOT the single wire type. Get the SEALED LED marker lights if available since they will be unaffected from any water.
  • There's one out there somewhere, the trick is finding it. If you can't, get one close. they are so far apart no one will ever know the difference if it's not a perfect match, or get all new ones. They are easy enough to install and cheap.
  • Amazon has a million of them. The trick is finding yours.
  • look in most any larger truck stop for a match.
  • That should be a DOT SAE AP2-03 fixture. Quick look did not find it.
    try contacting etrailer.
  • Look on your existing lights for identification. SAE number or manufacturer number.
