I've converted my entire TT lighting inside and out to LED. I purchased 194 leds for the clearance and marker lights with the led colors to match the lens colors and 5050smd 1157 in red for the tail/b...
If you could check the voltage at the light with the light on, and with no bulb, it will tell you more than just checking the voltage with no bulb. If the voltage drops with the bulb lit, you have a bad connection. If there are other lamps on the same circuit, unplug the fuse to see what other lights go out, that may help you locate the bad connection.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
