sjturbo
Oct 30, 2018Explorer
Thanks for linking!
I connected directly to an open 12V circuit on my converter > 14g silicone wire to the terminal block > terminal block to LED receiver > LED receiver to 16' LED extension via internal channel for the awning power > to LED light strip, (siliconed connection). Located the hole and connection for the running light. Drilled a small hole in the running light plate and ran the remote sensor to the hole. Done. I left out the 2hours plus that I used an electrical fish tape to run the 16' extension through the horizontal frame channel that was used for the awning power. Hope this helps.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
