rwbradley's avatar
rwbradley
LED Strip Light mod
I recently added a strip of adhesive LED strip lights (with remote and multi color).
What I needed:
- a strip of Outdoor LED strip lights for about $30 on Amazon
- an old 12v power brick (to cut off the brick and use the 12v adapter and wire) you can also use the brick that comes with the strip lights and just cut off the brick
- a small strip of scrap stick on data conduit
What I did:
- installed the strip light on the outside of the trailer just above the door with the power connector on the door side
- drilled a very small hole in the wall of the trailer (was very concerned about doing this but I went for it)
- mounted the IR box beside the door with 2 sided tape
- connected the strip light to the IR box
- ran the power cable into the trailer
- ran it over the door to the control box on the other side of the door
- removed the control box and wired the power cable into the Porch Light switch
- connected power cable to the IR box outside
- added some conduit to clean up the cable
- caulked around the IR box and hole
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Mar 11, 2026
