StirCrazy's avatar
StirCrazy
Moderator
Oct 28, 2023
LiFePO4 battery build
I got my new cells in today and I am going to start putting them together after I sort out whether I am getting a new cell or not, as one has some slight damage. It is probably fine to use but between shipping and duty charges I paid quite a bit for this set of cells so if they offer to send a new cell, I'll take it.
so, the cells I got for this build are EVEv304AH grade A cells. so, when I do get it together and do a capacity test, I am expecting more than 304 and possibly up to 320AH.
here is how they were packed
here is the damage on one of the cells
length
height
width
Anyway, what I want to know is if there is interest in me doing a thread on this build. People that have already built batteries probably wouldn't be interested much but it is more the people that are sitting on the fence about building their own. Also, I would want people who have done builds before to have input on how I make a case or whatever else. my last one wasn't in a case or compressed.
  • stir I've provided the link to proper li management many times.
    ScottG nice includes not using them at -34 F. I can't change the climate where I live.
    I think Li are wonderful when they are suited to the climate.
  • Given the way RV'rs will use lithium batteries, there's just no reason to worry about being nice to them (the batteries that is. We should always be nice to RV'rs..).
  • pianotuna wrote:
    Once every 30 cycles do a full recharge. The rest of the time charge to 85%. Try not to go below 20%. (40% would be even better for cycle life).
    The best way is to have a bms. Sure, it costs more--but no battery is cheap. So why not do it the best possible way?
    900 amp-hours is a respectable bank. I got to 875 in 2012.
    Where are you getting every 30 cycles from and do you even know why you charge to 100%, or for that matter do you even halve to? yes, lowering the actual amount of discharge you use will increase life but there are other ways to do it without losing capacity also. for example, uncompressed my cells have a cycle life of 4000 cycles at 100% discharge. do if I do that twice every weekend so 104 cycles per year, which will last me 38 years. by compressing them properly that will add another 1800 cycles to that 4000. but having said that the compression has the biggest effect in the first few cycles where it acts to squeeze out any air bubbles that are trapped in the cell during manufacturing, so I'll probably just compress them while I do my capacity testing and do 4 or 5 cycles of the battery.
    I already stated that I did have a BMS which makes me wonder do you even read the posts or just start spouting out after reading the first two lines?
    There is also a difference between your 875 of AGM which gets you about 437 of usable AH if you want them to last, probably less than that as you said they were used telecom jars which means they probably have already lost capacity. I will have 900AH which I can use 100% of if I like and they will outlast me.
    I will not be discharging 100%, I build my batteries to have between 5 and 10 days capacity if the solar breaks so normally I'll only discharge 10 to 20% and yes, I will be setting 90% as the top of this battery in the camper, but I won't be charging it to 100% ever, aside from the first few cycle tests. After that I will be adjusting the parameters to make 90% act as 100% so it will balance every time it gets to 90%.
    Admin's Edit: Removed some of the vitriol towards Pianotuna.
  • Once every 30 cycles do a full recharge. The rest of the time charge to 85%. Try not to go below 20%. (40% would be even better for cycle life).
  • Tom_M wrote:
    You will have to add a BMS to the build.
    Just wanted to discuss this point also. no you don't need a BMS, but for the way we use them in a rv I would agree and highly recommend that you use one. Before there were quality BMS or BMS that would handle a large number of cells, you used other things to control your shutoffs and didn't have things like low temp cut off unless you used a thermometer with an alarm.
    The major difference is how you balance them though, with a BMS you top balance so you can get the maximum charge into the pack. If you're just running raw cells you bottom balance, so all the cells reach their lowest state at the same time, without one cell going too low giving you a more predictable power floor. With a BMS this is controlled as it will shut down the batterie if any cell drops below the min setting so you don't need to top balance. Also, without a BMS you are normaly manually charging so you would be monitoring the cell voltage with a multimeter to get them to the point you want them.
    So, it is not necessary and lots of people don't use them, but they are a good send for automation all the stuff you would have to do manually. I don't see not having one as a good fit for a rv type situation theough.
  • pianotuna wrote:
    I would certainly ask for a replacement on grade A cells.
    What bms will you use or will you 'roll your own'?
    Costing would be of interest for sure.
    na Im not that ambitious to make my own BMS I got the same one I used in the camper build thinking I could parallel the batteries if I had to, but the camper is only 280 AH so that might have to be changed. ideally, I want to build two batteries for the 5th wheel and have the capability to add the camper one also to give me 900AH in there for them long family vacations where you want to run the beer fridge and the Margaritaville ;)
  • Tom_M wrote:
    I'd be interested in what your total cost will be. You will have to add a BMS to the build. Last year I purchased a FEENCE 100AH LiFePo4 "drop-in" battery which has a built in BMS for $300 from Amazon. Today it is selling for $179 - $10 coupon + $40 delivery, total $209.
    Here's a link to Amazon:
    https://www.amazon.com/LiFePO4-Battery-Rechargeable-Batteries-Trolling/dp/B0CJTWDRZR/ref=sr_1_5?crid=2AR3NVCGEC1VW&keywords=lifepo4+battery+100ah&qid=1698487797&sprefix=lifepo4%2Caps%2C302&sr=8-5&ufe=app_do%3Aamzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
    Here's a link to a YouTube video:
    https://www.youtube.com/watch?v=VsBtAroiLto
    I'll have to figure out the US pricing here, hang on..
    so, the cells were 134.00us each, so 536.US. my BMS was about 80.00US it's a 150 amp JBD smart BMS with Uart and Bluetooth (same one I used in the camper). I have had the BMS and a 23 bucks active balancer that I haven't decided if I am going to use. for quite a while now, I got scammed on an original order of cells so I went to an American distributer and paid a bit more than the original order was
    ya the cheapest we can find drop ins in Canada is about 450 plus tax and shipping for drop in's but, I would go this way anyways as it is the same power as three 100amps but smaller and probably a bit lighter also.
  • I would certainly ask for a replacement on grade A cells.
    X2
    Housted
  • I'd be interested in what your total cost will be. You will have to add a BMS to the build. Last year I purchased a FEENCE 100AH LiFePo4 "drop-in" battery which has a built in BMS for $300 from Amazon. Today it is selling for $179 - $10 coupon + $40 delivery, total $209.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
