msiminoff's avatar
msiminoff
Explorer II
Nov 21, 2014
Lighted Water Heater & Pump Switches
This may well be the most simple and inexpensive mod' ever, but hopefully somebody will find it useful...
While on a camping trip this past weekend, my wife commented that when she had gotten up to use the restroom in the middle of the night and she'd had a hard time figuring out which switch on the control panel to flip to turn the water pump on and off. Although there are power indicator lights at the bottom of the panel, the switches are challenging to identify in the dark.
This seemed like a easy problem to remedy; I stopped by my FLAPS and picked-up two illuminated rocker switches... one blue and one red ($3.69ea), and snapped them into the control panel where the black switches had been. The blue on is for the water pump and red is the water heater. Problem solved and DW is happy :)
Cheers,
-Mark
  • Good job. And, just to add to Scott's comment - the separate LED would make a great night light as well.
  • So the switches are lighted even though they are off? Seems like that would use up a bit of extra battery when boon docking if you do that. If not then it's all good.
    You could also have installed a small LED lamp to light the entire panel and it wouldn't take as much juice.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Jul 13, 2016
