valhalla360's avatar
valhalla360
Navigator
May 28, 2025
Lithium - Charging
Picked up a couple 12v 100amp-hr Lithium batteries off amazon ($150 each delivered including bluetooth monitoring). My charger has a lithium setting and I have 240w of solar.
I've had them installed for a couple of weeks. Getting used to the idea that we don't need them at 100% charge like the old lead acid. In fact, on the lithium setting on the charger, it wants to keep them at 100% and probably 90% of the time we are on shore power.
Most days, the solar replaces what we use but it's spring and had a lot of rainy overcast days. Since lithium doesn't like to be at 100% charge for long term,  I've been playing with it and put it back on the lead acid charging setting. I purposely ran them down and it does trigger the charger before they get too low to bring them back up to around 85%. Also, I figured out, if I cut power to the charger and then turn it back on, it goes into charging mode regardless of the current charge state, so it's an easy override, if we plan to boondock.
Thoughts on which would be best for this usage pattern:
 - Just leave it on the lithium setting and the batteries will spend most of their time at 100% except when boondocking.
 - Use the lead-acid setting and let it hang out in the 40-90% range depending on solar output...trigger the controller the night before if we are going to be boondocking.
No RepliesBe the first to reply
