time2roll
Apr 01, 2021Nomad
Depends on what you are driving. Yes lithium will accept more amps. If your connection to the battery is long it may have enough resistance to self regulate. A MH with a short fat connection could well put your alternator at max power. A DC-DC charger such as Renogy will limit the power. This will also isolate the house system so if you have a BIRD you may need to consider the limitations.
The Victron test was done on a bench not an RV.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
