- ependydadExplorer
MrWizard wrote:
ependydad wrote:
I opted for 12v drop-ins. Many of the benefits in a quick and easy drop-in package. Outside of the price and the issues with recharging below freezing (I try to avoid being in below freezing conditions!) - these were the best choice for me. The weight of them is crazy amazing.
http://learntorv.com/battery-upgrade/
you might want to correct this phraseIt seems that most people are opting for 6v batteries and wiring 2 in parallel to combine them to 12v. If they get multiple batteries, they’ll wire the pairs of 12v batteries in series to increase the size of their battery banks
you got that backwards , its 2 in series for 12v
"seried pairs" in parallel for large bank
Thanks MrWizard! I've fixed it. - MrWizardModerator
"seried pairs" in parallel for large bank - Model S most definitely has a battery heater operating when the vehicle is on in the cold.
Also on when charging in the cold. - free_radicalExplorer
time2roll wrote:
pianotuna wrote:
Since powerwall is generally constant on the grid I assume it includes a heater and cooling fan.
The issue of cold weather charging is a deal breaker for me, and probably always will be.
Otherwise best to have lithium in a heated compartment in very cold conditions.
Hmmm,,I wonder how does Tesla batery stay warm in very cold temps..?
Sleeping in Tesla in -17C
https://youtu.be/2WeOc9qWujA - ependydadExplorerI opted for 12v drop-ins. Many of the benefits in a quick and easy drop-in package. Outside of the price and the issues with recharging below freezing (I try to avoid being in below freezing conditions!) - these were the best choice for me. The weight of them is crazy amazing.
Otherwise best to have lithium in a heated compartment in very cold conditions.- pianotunaNomad IIIThe whole thrust of the powerwall is grid tied. It won't work without the grid. Work arounds are possible.
The used Li battery bank is intriguing, but the cost may be prohibitive. My bank has about 6 kwh of which 3 may be used. Cost was under $500.00. If they could get the voltage down to a nominal 12, then it would not be so costly to upgrade.
The issue of cold weather charging is a deal breaker for me, and probably always will be.free radical wrote:
Just wondering could Tesla powerpack be used for Rvs?
https://www.tesla.com/en_CA/powerwall
Just noticed the price,so thats probably no no for most of us here..:)
How about some used Lion batts,,could those be made to work in RV?
http://www.evwest.com/catalog/product_info.php?products_id=463 - MrWizardModeratori recently looked at that site, and those Telsa batteries
200miles per charge cycle, 100,000 miles aka 500 cycles to loose 15% capacity
1000 cyles batterys down to 3829 watt hrs aka 3.8KwHrs
5.3kwhr $1450 $0.274 per KWhr, plus new inverter, plus new charger etc..
10% of the weight of my 675 AmpHr aka 8000 watt hr aka 8.0 KwHr AGM bank
4kw useable to 50% cost $350 $0.087 per useable watthr based on 4kw 50% use
will the weight difference save $1100 worth of fuel over the life span of the lithium ? will they last 5yrs and 1800 cycles , will they last 10 or 15yrs
at 3 times the cost per KW hr, they need too, just to balance out the cost effectiveness of surplus AGM
and this is a ROLL your Own DIY system
2oldman can tell you about the cost of a ready to install retail Li battery
perhaps i'll change my mind in a year or TWO, but not today - If you have the space and weight capacity powerwall should work fine.
I would not bother unless it was a 50 amp RV. Good luck getting Tesla to install. Not sure they do carry out.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,390 PostsLatest Activity: Sep 15, 2025
