pvelit
Feb 27, 2020Explorer
Thank you guys for your responses!
I was just worried about how the converter will behave when putting the "Voltage Booster" before the battery. I understand that the converter determines the
charging stage (Float, bulk, etc) automatically by reading the battery voltage. However, with the "Voltage booster" in between, I have no idea what charging stage the converter will pick? What voltage will it read from it?
I guess I will have to test it... I was hoping someone had tried this.
Replacing the converter to a Lithium compatible one will cost me around $200. Instead, if this works, I will spend only $15 for the Voltage Booster... just trying to save some money.
Thank you,
Paul
Thank you,
Paul
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
