2oldman
Feb 28, 2020Explorer II
ScottG wrote:Not from what I've seen. Li's need a charger rated for their needs. Now, whether an acid charger would actually damage an Li, that I do not know.
So you could drop any BMS equiped LI battery into a common, converter charger designed system for standard wet-cell batteries and it would do fine on its own?
A BMS does a lot of things, as pointed out in the OP's batteries' spec sheet, but it does not change the input charging voltage to what it requires.. if that's your question.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
