CA_Traveler
Sep 22, 2014Explorer III
If he can get through the ceiling then that's a good option otherwise run the wires on the roof.
If the grounds are common then he only needs to run 2 wires from the front to back speaker on one side. ie Connect front speaker wire source to rear speaker and rear speaker wire source to front speaker. Otherwise it's 4 wires. No need for any vertical wiring.
OP Connect the speakers with some temporary wiring inside the rig to see if this works for you.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
