Jagtech
Sep 22, 2014Explorer
colliehauler wrote:robsouth wrote:Robsouth is correct. There is only two wires running to the living room and 2 to the bedroom. You need 4 wires for stereo.Jagtech wrote:
Why don't you just change the wiring at the back of the stereo so that the proper pairs go to the appropriate speakers?
That likely will not work from what OP described.
If you are a bit creative, it can be done with 2 wires. One wire will be Left (+L) and the other will be Right (+R). The return side of each speaker will be chassis ground. pretty much any metal connection point near the speakers that is common with the chassis. In the rear of the stereo, the L- and R- must be connected to chassis ground. On some stereos this may not work, as some models require the outputs be isolated from ground. The original 2 wires can then be connected to L+ and R+.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
