exploringcaroli's avatar
Aug 10, 2014
LivinLite CampLite Counter Top, Floor, TV, Microwave, Bed
We purchased a new 2010 CampLite 11 a few years ago. It's an early CampLite off of the LivinLite 2010 production line. This CampLite came equipped with 13,500BTU AC & portable water tank under the sink with a manually operated pump faucet. It also has a empty weight of 1,400 pounds and 2,200 GVW.
We wanted additional counter top space and to try camping without water tank & sink. This CampLite did not have LP gas system, stove, and furnace. Started using paper plates, cleaning coffee maker, electric skillet, coffee mugs, and hands with Clorox wipes. Carry bottled water for Coffee & drinking.
While visiting "Lil' Snoozy" manufacturing plant in South Carolina, picked up an idea. They use 120V double burner range top for cooking. Most campgrounds we visit have electric hookups, so we decided to start cooking with a Teflon coated electric skillet and heating with a ceramic heater. Eventually added a $28 700W microwave.
"Lil' Snoozy" also uses a Cassette Toilet without black water tank. Like this idea, too. We decided to carry a porta potty to prevent the middle of the night trip to the restroom. "If" we move up to a larger camper, want to have a Cassette Toilet installed.
We keep a 35 quart Engle Deep Blue high performance 35 quart ice chest in the back of the pickup with Leer shell to keep the animals out at night.
Original Sink:
Wide angle view of the new counter top and dinette set up as a permanent 60"X80" Queen bed with memory foam mattress. Use gaucho couch with portable aluminum table as a dinette.
Made brackets out of aluminum angle to secure the TV:
Attic antenna used with an old camera tripod:
Used aluminum angle to secure the microwave:
Aluminum floor:
Purchased interlocking vinyl tile for $6.50 per tile at Lowes and installed directly over aluminum floor:
Made 23 pound bicycle transport system using roof bike attaching mounts on plywood inside camper:
After these modification checked the new trailer weight to be sure it was within GVW.
GVW 2200 pounds
New Trailer weight ready to camp
without bicycles 1,940 pounds
New Tongue weight 300 pounds
New axle weight 1,640 pounds
Bicycle rack & two bicycles 85 pounds
Trailer weight with bicycles 2,035 pounds
  • Really appreciate the kind comments from everyone!!!!!!
    Francesca, The interlocking tile seams are visible and very tight, but cannot be seen in the complete floor photo, no sealant used. The floor installation was our last modification.
    We have camped in temps down to the 20s so far and you can imagine how cool the bare aluminum is where there are no rugs. These tiles are for covering garage floors and very tough. Will use rugs over the new floor, too.
    It really surprised me how quickly a camper gains weight with mods, but "very" happy it came in under the GVW at full camping weight.
    Thanks Again!
  • Francesca Knowles wrote:
    Times two on that flooring- I can't even see the seams! Is that a trick of the light, or is there some sort of sealer involved?
    good job but I think I can see a seam under hand/cutter handle end and another one 18?" over about 3 dots from the end under the metal bar.
    bumpy
  • Times two on that flooring- I can't even see the seams! Is that a trick of the light, or is there some sort of sealer involved?
  • Bill,
    Nice job and nice post! :) You have really made that little camper your own.
    I especially like that floor.
    Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
