jjrbus's avatar
jjrbus
Looking for Honda sound box post.
Some time ago a sound box for a Honda generator was posted and have tried searching but does not show up. I want to show it to someone, anyone know how to find it?? I believe the mans name was Jorgenson??
  • theoldwizard1 wrote:
    Fans are CRITICAL if you are putting a generator in a box.
    I had cobbled a box together 4 years ago and used muffin fans. Was not impressed with them and changed to a radiator 7 inch fan. worked great. However the box stuck out too far and was too low.
    Making a new box now and trying to do it without a fan. Little Honda is running hot. 93 degree day and unit is running 105, measured under the handle on the case. Likely ok but I am not happy with it and not sure if more air needs to come in or I positioned vents wrong??
    The old setup with fan would run a few degrees above ambient.
  • Will the generators get enough cooling, air flow, to keep them from over heating inside those boxes?
  • Thank you it was the jauguston one I was looking for!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
