ajriding
Jan 16, 2020Explorer II
Looking ideas pop up roof section
I have a small cargo trailer I use often and want to do some overnights in it.
It is only 5 feet interior height, great for towing, not so much for standing.
I want to have one section where I can stand upright, so am thinking to cut out a 2x4 foot section of roof and having something that can easily raise, fold out, yet be flat with roof for towing, no more than 4 inches high when down.
My current idea is use plywood and make an A-frame roof that unfolds so has some headroom. (i have epoxy resin to waterproof the wood)
I can't yet figure how to keep it watertight. Folded down is not such a challenge, but having 4 panels fold out and all be weatherproof is the challenge. Two side will be rectangle panels and the other two will be triangles. The triangle will fold up last and remain under the eeves. At the bottom to keep it all water tight Im still pondering.
I also want to operate ir all from inside, and also need a way to secure it while driving.
I have seen hurricane hinges, but they are not shaped right. I have seen plastic hinges (like piano hinges) that just bend, so there is no leaks,but I ant find sources for these, or can only find expensive ones. Maybe tack down vinyl over a piano hinge.
Anyone ever do something like this, or have a better design to add height? I do not want to do a complicated engineering feat as this will be a minor project given available time.
