grimmrlg
Jul 12, 2015Explorer
The bracket is bolted to the C channel frame with 4 - 3/8" bolts. I considered welding directly to the frame but wanted to be able to remove if necessary. Since the storage area floor is made up of 1/4" ply sandwiching 1" styrofoam, the jacks go through a large clearance hole and bolt directly to the bracket from the top with 3 - 3/8" bolts as supplied with the jack. No issues with strength of the 1/4" gussetted brackets.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
