iagary
Aug 25, 2016Explorer
Another question related to this subject. I converted my Campfire In A Can to run off the low pressure RV hose. I installed quick connects on the regulator as well so I could quickly put it back on if I wanted to run directly off a tank. Does anyone see any problem doing the same with my Weber Q? I would put a tank connector on the inlet side of the regulator and a female quick disconnect on the outlet side. Then I would attach the regulator directly to the tank and then a quick disconnect hose to the grill. Any problems?
THANKS!
THANKS!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
