johninedmonton's avatar
Jun 01, 2014
Lowering My Batteries
Hi guys;
I have 2 6V batteries on my trailer. I'd like to relocate them, or perhaps my 2 30LB propane tanks, so that I can create more room on the tongue of my TT.
My goal is to mount a bike rack in their place, so that I can get our 6 bikes on the TT (4 kids, wife and me).
Does anyone have any experience with this idea? Thoughts? Suggestions?
Thanks!
  • Seems like it would work. Having someone weld up a steel angle iron frame that would allow the batteries to drop down 4"-6" wouldn't be difficult. You couldn't go too low or it may drag on speed bumps or other obstacles.
  • Thanks guys. I'm not thinking I can get all six onto a single rack. Sorry, i should have explained this better. I'll hang 2 from the ladder in the back. I still need to find somewhere to put the 4.
    My thought was to lower the batteries a few inches, inside of the a-frame of the tongue. That would allow me to move the tanks back a bit more, thus giving me the room needed to mount a bike rack.
    Has anyone ever dropped their batteries like that? Is there a reason I shouldn't?
  • Perhaps you've done a detailed analysis on this, but I've never seen or heard of a six bike holder over the a-frame, whether a manufactured unit (Arvika or Bike bunk) or the many homemade units shown in this forum. The space needed for 6 bikes may result in your TV hitting the bikes when backing or turning corners.
    But if you have it figured out, we'd love to see the photos when you are done.
  • RoyB's avatar
    RoyB
    Explorer III
    I don't think I would want to relocate the batteries and propane tanks. You won't find a SAFER place to have these units on your TT. Moving the Batteries and Propane to the inside of the trailer if you had room would require proper venting and fluid retention from batteries boiling out or spills etc. Rerouting of battery cable wiring and propane lines would be another headache to contend with.
    I'm thinking you can mount a metal battery box like this 48-inch side mount tool box between your propane tanks and the front wall of the trailer.
    Looks like you have plenty of room with your 2013 Sport trex to do this...
    Photo from GOOGLE IMAGES
    The BATTERY BOX would look something like this. This style metal box will hold four each GC2 6VDC Golf cart batteries. The metal battery box will add thief security for your batteries.
    Photo from GILLDAWG79
    I believe you will be able to mount many bicycles over the top of the battery box using the appropriate bike mounting kits. The bicycle mount will use the trailer frame for primary support.. You should be able to extend the bicycle mount out over the top of the propane tanks and run a support frame from the front end of the tongue area as well. Three bicycles are shown here. You may have to engineer a hinge arrangement near the the front of the trailer so once you remove the bicycles you can hinge up the frame to gain access to the battery box and propane tanks.
    Maybe four main supports from the trailer frame going up from both side of the PROPANE TANKS would be sufficient to hold the bicycle rack for six units. The rack would extend back toward the front of the trailer as well forward over the top of the propane tank... You can have a few different solutions here to support the bicycle frame from the trailer tongue area.
    Just some of my thoughts here...
    Roy Ken
