Crazyatvrider36's avatar
Feb 12, 2017
LVP FLOORING??
I have a 2007 Weekend Warrior toy hauler. I had some soft spots in the flooring I had to fix due to the water heater that started leaking. Also the existing vinyl started cracking. So I replaced the flooring with plywood and am trying to decide what flooring to put back down. Currently we had linoleum just in a smaller area up front in the bathroom, hall and kitchen. The main rear is just osb and we layout the carpet when we aren't hauling anything. I like the look of the newer toy haulers where it looks like they use vinyl or linoleum through out the whole thing, just wasn't sure how well it held up driving the toys in. We carry 3 to 4 four wheelers and I usually turn them sideways to fit them in. I've talked to a couple local flooring stores and they both recommended the luxury vinyl plank flooring (LVP) and glue it down with pressure sensitive glue. Then if I ruin a plank I will just pull it up and put in a new one. Similar to how carpet squares are put down. They said I would have to use a floor patch to level and also so the glue would stick to the osb. So I'm kinda on the fence as I should just do that for the front end like it was and try it out, or go for the newer look and lay it through the whole thing and get the newer look I want. I'm just concerned about 4 wheelers causing problems, or seams separating due to driving on them or expansion from the extreme hot and cold when it's sitting. I like the idea that if I do have a problem I just keep extra and put a new piece down. This stuff seems to be relatively new and the flooring guys seem to think it's the best way to go and should hold up very well. Has anyone else done this or does anyone have any suggestions???
  • Imo the leveling glue does three things
    It seals the osb
    It gives a smooth surface for the contact adhesive
    It prevents the osb from being pulled up if you remove planks
    Planks are Not made to be replaceable, not if they interlock
    Use a one sheet product, or squares that can be removed and replaced
  • Couple of points. I've never heard of anyone ever recommending putting glue down flooring over OSB. Ever. Also the planks are interlocking and are not intended for easy replacement. Sheet goods are the best bet in my opinion. The high end goods are crazy tough and can float and be secured around the edges. Also with the vehicles there is no seam for drips and water to get into your substrate. OSB does not like water.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
