Gjac
Jun 01, 2014Explorer III
I bought the lightning rod and it worked well. It needs to be removed any way to drain the tank for winterizing. The main draw back is that if it is turned on with out water in the tank it will burn out. The replacement elements are quite expensive $40 or more compared to $12 or so for the ones you would by at HD or Lowes that are used in regular water heaters. I have not been able to find a a cheap replacement element for it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
