lawrosa's avatar
lawrosa
Microwave off Inverter. Volt drop with 3 batts parallel
Here's a vid of more of my set up. Running micro off inverter to see a better idea of volt drop with 3 batts parallel.
I dont make exciting vids but it shows more or less how I boondock..
I know this vid may not show anything at all as I only had the micro running a few minutes.. Probably a waste of youtube time... lolol
1. Rule one. Waste of time running the Micro off inverter. especially a modsine type. I just dont have enough invert power . You need puresine at least.
To me its a popcorn maker and coffee warmer.
And again as I discussed elsewhere I dont need to use the coffee pot or the toaster oven as I have a perculator and an RV oven.
But I am torn between keeping 12's or going 6 volt.
If I went 6 volt I will probably do away with the truck battery, as it will not be needed.
Plus I dont know the effects of ampdraw from the RV batts down the wire of 7 pin 20 ft of maybe #8 wire.
https://www.youtube.com/watch?v=wz2ttT8fFLc&t=16s
  • azrving wrote:
    Youtube isn't working well for me right now but you are saying that your inverter is wired to one rv battery and then pulling from two 12 volt truck starting batteries through the 7 way wire?
    The other way around - as I recall the OP has 2 G24 trailer batteries and a third G24 sitting in the engine compartment of his truck ... truck starting battery isn't involved in this. That G24 under the hood he has wired through a 7-pin Bargman - a poor solution when using heavy gauge booster cables would result in far less voltage drop.
  • Youtube isn't working well for me right now but you are saying that your inverter is wired to one rv battery and then pulling from two 12 volt truck starting batteries through the 7 way wire?
    Horrible. :M Forget the Bargman cable and use heavy gauge booster cables, the heavier and shorter the better. I'd prefer to use at least 2 gauge but any sold around here are too long and too expensive so recently bought a 16' 4 gauge set but may cut it even shorter to reduce voltage drop even further when I load support my trailer battery with my truck.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
