tenbear wrote:
Looks good Ron. Did you use the meters that display both voltage and current?
I have the amp meter. But have not mounted it yet. Problem is Inverter and DC distribution are on opposite side of MH from the monitor panel. To save on wiring I am probably going to mount that meter in panel that has Inverter control in it. I will probably put 2 meters there. One for Inverter and other for DC distribution. My other thought is why mount it. When running on inverter I keep the AGS on. When voltage gets to 12 VDC. Generator starts. We only use these 2 features when traveling for overnight stops in rest area and other no shore power locations. Do not have Solar.
