the_bear_II
Mar 18, 2016Explorer
I haven't changed my axles but I did replace all of the springs which is basically the same process.
I used a bottle jack and a floor jack plus jack stands and lots of 2X4 & 2X6s as stacks for the jack stands. Get the trailer up on to the jack stands, then remove the tires, support the first axle and remove the springs and shackles. I was able to complete the 4 spring change in a weekend working by myself.
You'll need help with the axles.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
