phillyg
Mar 18, 2016Explorer II
Mechanically it's simply a parts swap. Unbolt and remove, install and bolt up. But, it would be easier with two people, and you need to ensure the axles are aligned relative to each other and the frame. Upgrade the hubs and brakes while you're at it; they're no all that expensive. OTOH, I agree you're probably not overweight and you probably don't need to upgrade at all, but that's your choice.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
