Rvpapa
Mar 18, 2016Explorer
Do a bit of research and I think that you will find they are the same as 7000lb axles. The only difference is the spring packs. Manufacturer put on the proper size for the unit weight. Put on heavier rated and all you do it hammer the s+++ out of the trailer on rough roads.
Art.
Art.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
