mapguy
Mar 19, 2016Explorer
corvettekent wrote:djgodden wrote:
So... can I simply change the axles and use the same hub/brakes or would those have to be changed as well?
No you can't use the same hubs.
Yes, 8 lug hubs from D52 axle are usable to D60 & D70 axles. Might need to upgrade the brake backing plate assembly depending on final axle capacity choice though. Disc brake upgrade time if really want to increase overall safety -which seems to be OP's intent.
Research at dexteraxle.com will verify my comments.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
