1L243
May 25, 2021Explorer II
kfp673 wrote:
Did this 2 months ago as well. Thanks to this forum, I also learned that greasing is much easier with weight off the springs. I had 4 points not take grease until I jacked it back up and then no problem.
One thing I am considering is adding the X factor cross member. did you do that? Anyone do that with the 3000?
Yes, I was thinking of going with the X Factor cross bar. Not only for front and rear axles but for the Equalizer hanger as well.
BUT
I have a problem with the Black tank drain pipe running in front of the front axle hanger bracket PLUS the Gray Tank drain pipe runs in front of the rear axle hanger bracket.
If, I get real excited to do this I may reroute some plumbing but for now it's on the back burner.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
