Grit_dog
May 26, 2021Trailblazer
kfp673 wrote:
Did this 2 months ago as well. Thanks to this forum, I also learned that greasing is much easier with weight off the springs. I had 4 points not take grease until I jacked it back up and then no problem.
One thing I am considering is adding the X factor cross member. did you do that? Anyone do that with the 3000?
10-4
If the port in the bolt is facing up (no way to tell from the outside ) then you’re effectively fighting the weight on the bolt when trying to grease.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
